How to have an axial load in modal analysis
Hi,I want to have axial load in a modal analysis but I can't do that because the Force option is gray.
Thanks in advance for any help
RE: How to have an axial load in modal analysis
See FAQ569-1083: Asking questions the smart way on Eng-Tips fora for details on how to make best use of Eng-Tips.com
If you use workbench, then add a structural environment using axial load. On the solution tab, right click and then choose "transfer data to new modal analysis" then conduct the modal run.
Raj
