Cold Box Heat Exchanger
Does anyone in the forum has some good literature on Cold Box Heat Exchanger.
If yes, then please do share.
Thanks in advance.
Dinesh S SHELATKAR
Process Engineer
RE: Cold Box Heat Exchanger
"Cold box" denotes an insulated environment in which cryogenic equipment (heat exchangers, pumps etc.) is installed, for preservation of cold. There are several types of exchangers used in cryogenic processing: Brazed Aluminum (BAHX), stainless Shell & Tube, Printed Circuit (PCHE), and Spiral Wound Heat Exchangers (SWHE).
AIGA has standards dedicated to Perlite insulation and Design/Operation of cryogenic enclosures (see the last two links below). Try Google-ing the web sites of CHART, Linde, Kobelco, Air Products, Fives Cryogenics, etc. for more information.
For BAHX, there is ALPEMA standard which covers design and construction of Brazed Aluminum exchangers. http://www.alpema.org/index.html
http://cryogenics-energy.fivesgroup.com/equipment/...
http://www.linde-engineering.com/internet.global.l...
http://www.chartindustries.com/Energy/Energy-Produ...
http://www.kobelco.co.jp/english/machinery/product...
http://www.hts.org.uk/downloads/Linde_LNG_HEX_09De...
http://www.asiaiga.org/docs/AIGA%20032_12%20Perlit...
http://www.asiaiga.org/docs/AIGA%20079_12%20Safe%2...
Dejan IVANOVIC
Process Engineer, MSChE
Thanks a ton mate for the valuable information.
Dinesh S SHELATKAR
Process Engineer
I can share some literature. Please send me your email
Talk to vendors, it may help
Alpema has a good standard.
Gabriel Castaneda, P.E.
http://www.gabcheminc.com
