Temperature limiation for using external pressure charts
UG-20 (c) states ""design temperatures for vessels under external pressure shall not exceed the maximum temperatures given on the external pressure charts."
Sec IID,Appendix-3,Fig-3-500.1 shows the temperature limitation for each material for the actual r/t ratio. For my case I have material SA240 304H, at 770°C, r/t ratio is 23.5. If I refer this curve of ss304H in Fig-3-500.1, I found I can not use external pressure charts for more than ~475°C.
If we refer external pressure chart HA-1 for SS304H material, the maximum temperature curve available is up to 815°C.
Commercial s/w available for pressure vessel design do not limit temperature as per Fig-3-500.1 and directly refer the curve as provided in external pressure chart. And if curve is available they don't check the limitation for use as per Fig 3-500.1.
Please share the interpretation on this. What should be right approach and interpretation?
RE: Temperature limiation for using external pressure charts
http://www.eng-tips.com/viewthread.cfm?qid=123610
