calculate bolt size to hang equipment
I have a piece of equipment that will be hung from the ceiling. I need to determine the proper size and quantity of bolts to hold in place. Help please! Thanks!
RE: calculate bolt size to hang equipment
This sounds like a good project to hand over to a qualified engineer.
JHG
1) Bolt/screw shank nominal diameter
2) Bolt/screw Material
There are standard ultimate load values in MMPDS Table 8.1.5 (b1) and (b2).
For example, if you are using an alloy steel #10-32 (NAS517) screw, ultimate load per screw will be 2890lb per screw.
You can use what ever safety factor you need, say 1.5, yeah go for it, why not. If I were you, I'd worry about the structure above the bolts.. just saying.
www.stressebook.com
Stressing Stresslessly!
Read you're post and look at the information provided, based on that information how would you help somebody.
Again, assuming the thing is designed to be hung, the size of the holes in the thing's mounting brackets are a good guide.
Mike
Your question cannot be answered as written.
Should have kept that comment to yourself. IMHO, these kinds of posts are not good to get involved with. Clearly as a layperson, Epgasser could misconstrue advice given and make a very poor mistake.
"It is imperative Cunth doesn't get his hands on those codes."
Vagueness begets vaguenss.
Mike
