Rising water table
Rising water table
Hello and sorry for the repost
I am currently working on a survey of a bay . during the excavation task in order to construct a drainage network , water level from the sea has rose up in one trench as shown in these pictures .
http://www.servimg.com/view/14121133/182
http://www.servimg.com/view/14121133/183
Now i know common solutions requires the use of poorly graded gravel and or special cement. I would be happy if you direct me into case studies or books that relates to this problem.
RE: Rising water table
Do a Google search for "subsurface drainage". Here is one that came up.
http://www.wq.illinois.edu/dg/subsurface.htm
Also try "stabilizing trench base".
the project consist of the construction of an area for containers ( wharf or dock if you will) . We start by doing excavations up to 60 cm then proceed by lying down a geotextil for filtration
a sand layer of 6 cm is put above the geotextil , followed by a layer of compacted aggregates about 29 cm . In the end , we construct RC slabs .
The project also mention the construction of an underground drainage system , and this is where we see the water rising . Modifying the whole project cannot be done , but solving the issue of the water is what i am looking for , i will be viewing your suggestion
PS: i should also add that the soil profile consists of a sandy silt with organic presences here and then
Immediately in back of the excavator lower in a drainage pipe consisting of flexible corrugated plastic, with small slots, perhaps 2 or 3 mm and wrappped with a filter fabric sock. As soon as possible then backfill over that pipe, sufficient thickness to "bury" the pipe. The backfill over and around the pipe should be a graded sand , such as ASTM C-33 fine aggregate for concrete. DO NOT USE THE COARSE AGGREGATE FOR CONCRETE, SINCE IT IS NOT A FILTER. This filter zone could be in the range of 15 cm or more depth. Later use what ever soil came from the trench to get up to finish grade.
If you have to work in an already dug trench, lowering the water level a little with pumping can be done, but not so extensive as to remove all water and cause loosening of the soil below the trench. I'd try to work without any pumping.
That ASTM-C33 concrete coarse fine aggregate sand is a perfect filter for all soils. You do not need any filter fabric in the trench first. Even a slotted pipe without a filter sock will work, but a little sand gets in first and then bridges over the slots. Since the pipe is not fully surrounded with soil, the dumping on top of it will likely surround it sufficiently. A fussy way would be to place the sand in a thin layer first and then the pipe, but that takes time and may not be practical.
Size the pipe to carry the estimated flow. In the States, I'd use 4 inch for lengths of up to 100 meters, and 6" for all others. Here these flexible pipes come in rolls for ease of handling. I'd not get too fussy about meeting a sloping grade under the circumstances you have. So some low areas result, so what. It will still work.
i don't know its name in English but in French its called Avaloire . So this element is a RC structure , each unit connects with the next one via PVC conduits .
This is my first experience with underground drainage , but i know the problems that may associates with this are :
1- these structures were never designed correctly , even for this kind of important projects( Docks) they are given standard dimensions and whats more standard steel reinforcement. Therefore , and especially with the existence of heavy containers , bearing capacity is a big issue .
2-Buoyancy since they will be constructed under water levels , note that no knowledge of the the most critical ground water level is known !
3-Possible infiltration of sea water inside the drainage system which can render the latter useless in accordance to their initial function, and may even cause flooding and collapsing
( we did similar projects for the same client and the collapsing of underground drainage network is very common )
Off hand other than being able to just place the pipe and backfill with no special stabilizing of trench, I'd look to dewatering the soil ahead of trenching with a bank of well points located between the work area and the open water. The aim of that would be to cut off a flow of ground water from the most likely nearby source. It may take several such "banks of wells".
They might have good ideas as to what to do.
http://www.globalspec.com/FeaturedProducts/Detail/...
but you didn't answer my concerns regarding the RC structures . Anyway, i am considering using a precast RC boxes with damp-proof products . the base of the box must be designed to withstand buoyancy all the while providing adequate bearing capacity, maybe i should add pumping wells but the prob is that there is no way for the company doing the project, to be financed for tasks that does not exist in the contract you see....
RC structures also can be affected by salt water. I'd have to defer to those living and working in sea coast areas for advice on that. I'm way inland.
https://www.excelcalcs.com/repository/fluids/pipin... check this excel paper that deals with issues mentioned above
thanks a lot
Usually those inspecting or providing site measurements, etc. do not have authority to direct any of the work, or they are responsible for the results. They also can't direct any special work, such as dewatering. In this case, it probably is up to the contractor to complain to the owner that he cannot perform due to "changed conditions". It may be that a revised design or other change can be forthcoming, but generally not without an agreement of the cost thereof. Where the contractor is quite experienced, he may suggest a site treatment, such as well points, that had not been anticipated (due to some plan information). He may even go ahead and do the work, but may then claim extra cost due to that unanticipated work.
However, on this post, it would not appear that you have any authority to direct such work, without an agreement as to who pays. I'd report the conditions to your superiors, possibly with some comments on how to handle the change of conditions.
Document all conversations and keep a detailed diary. It may be needed in court some day.
