API code for Point Surface Joint
Hi all,
I am developing the macro for Kinematics Joints. I do not know the how to create the code for Point Surface Joint.
Could anyone help me to get the API for Point surface joint in DMU. I know the references for this one
Reference 1 -Surface
Reference2-Point
I do not know for the API for the adding the Joint.
jntRigid = varNewMech.AddJoint("CATKinRigidJoint", arrJointParams)
I would like to know what kind of API for Point surface joint as like as CATKinRigidJoint
Thanks in Advance for your help.
RE: API code for Point Surface Joint
did you check the online doc?... it's all there
Eric N.
check in working with Kinematics / use Cases / Creating a Mechanism in the chm file
Eric N.
