Exporting Asssly with child components out of teamcenter, Child parts as dump bodies in part files.
I want to deliver assly to customer and customer need dumb file i.e components without features. Is it possbile to take assly outside the teamcenter and automatically the child parts features can get removed and part should have only Dumb bodies. but the assly should remain same.
Suyog Patil
CAD Enginer
NX 7.5. 8, 8.5 9, 10 TC-9
RE: Exporting Asssly with child components out of teamcenter, Child parts as dump bodies in part files.
I will suggest to export the entire assembly outside teamcenter ,to the native environment.
Afterwards open assembly im NX native ,and remove all parameters from each component...
It can easyli be done....
( Think about - if you try to remove parameters on the fly in the TC environment, all parts needed to be saved,before export,
because "export outside teamcenter" extract data from disk (database) and not what is in current RAM.)
lklo
Suyog Patil
CAD Enginer
I thought you would do some programming....
see this sample: http://nxjournaling.com/content/creating-subroutin...
lklo
www.nxjournaling.com
Suyog Patil
CAD Enginer
Parasolid may not maintain the assembly structure if your assembly runs more than one level deep.
