Long Weld Neck Calculation
What calculation do I use to determine the min. material thickness of a Long Weld Neck?
RE: Long Weld Neck Calculation
On the other hand, you still have to check the normal nozzle reinforcement calculations by doing ASME calculations from the applicable section.
As dimension X is bigger than a normal weld neck flange at the weld connection, you are normally Ok.
If you want to make sure, then use the same calculation as you would for your connecting pipes.
