Rising water table
Rising water table
Hello
I am currently working on a survey of a bay . during the excavation task in order to construct a drainage network , water level from the sea has rose up in one trench as shown in these pictures .
http://www.servimg.com/view/14121133/182
http://www.servimg.com/view/14121133/183
Now i know common solutions requires the use of poorly graded gravel and or special cement. I would be happy if you direct me into case studies or books that relates to this problem.
RE: Rising water table
Mike McCann, PE, SE (WA)
