Buffer tank sizing
Buffer tank sizing
Hallo!
I have a task to determine dimensions of a buffer tank for nitrogen.
Tank must ensure enough quantity of nitrogen to supply working equipment for 10 [min], with pressure 7 [barg] and with flow rate of 4 [Nm3/ min].
Working temperature is -10 to +40 [°C].
Tank is filled up to 15 [bar] and during the working period of 10 [min] it can drop to minimum 10 [bar].
How big tank (buffer) [m3] do i need?
Thank You!
Thank You!
RE: Buffer tank sizing
You know the outlet flow at standard conditions - (flow times time) convert this to an actual volume at a mid point between min pressure and max pressure = Vout
Then add this to the volume left in the tank at the end of your 10 minutes = Vtx10bar = V finish
Volume of gas at start = Vt x 15= Vstart
V start= Vfinish + Vout
All pretty rough and you will need to check with compressibility factors, but will give you a start point.
The calculation is for Instrument Air but there is absolutely no difference if applied for Nitrogen.
Dejan IVANOVIC
Process Engineer, MSChE
Thank you EmmanuelTop, this helped a lot, that is excelant literature.
(Hvala zemljace, ovo je bas pomoglo, odlicna je literatura.) :)
Dejan IVANOVIC
I have one more question, when i calculate the volume of the tank i get 8,1 m3. Is this volume expressed in Nm3 or in m3 (working conditions)?
In other word, do i have to divide 8,1 m3 with 10 bar and get volume of 0,8 m3 (800 lit)?
Dejan IVANOVIC
And C is the book is also in Sm3/ hr.
Dejan IVANOVIC
Diameter for example 1,8 m and length 3 m.
Dejan IVANOVIC
What is the definition of Nm³ ?
Dejan IVANOVIC
Dejan IVANOVIC
p1=15 bar
p2=10 bar
p1xV1=p2xV2
V2=1,5xV1
V2-V1=4Nm3/minx10min=40 Nm3
1,5xV1-V1=40 Nm3
0,5xV1=40 Nm3
V1=80 Nm3
V2=1,5xV1=120 Nm3
V2r= 120 x 1,01325/16,01325 = 7,59 m3
My point was how is Nm3 defined?? What does N stand for - Nominal??, Natural?? Nitrogen?? N in a unit is normally used for Newtons. Sm3 is a much more commonly used term.
http://www.eng-tips.com/viewthread.cfm?qid=97506
Actually, NormalMetersCubed per Minute is a MASS Flow Rate, although it appears to be a volumetric flow rate, examination of the fundamental definitions will show that it is indeed a mass flow rate. The volume concept was developed so lay people would have some grasp of the quantity, but the real definition is indeed mass flow rate. Same for SCFM (Standard Cubic Feet per Minute, also a mass flow, no doubt about that.
