requirement torque for bolt tighting
When we want to tight the reactor bolts , is it necessary to have hot bolting?
However for bolt tighting , how much torque we need in the cold condition ot hot condition?
RE: requirement torque for bolt tighting
manufacturer has its value on data sheet or else you can refer to client specification..
My recommendation is that you should hire an expert in bolted flange joints. This is a specialty that takes decades to learn and hone - things that cannot be had for free anonymously over the internet. This recommendation doesn't necessarily mean that you should hire a bolting contractor, though.
Where in the world are you located?
What is the reactor fabricator and manufactor requirements? HINT: They know how they designed the bolts and pressure vessel head!
similar to above ... "reactor" and asking for advice from an online forum scares the crap out of me.
If the manual calls for hot bolting, that's what needs to be done.
