Design length_UG-29 & UG-80
Hello everyone,
As per UG-29 & UG-80 , To find chord length & e which length L0 should consider?
For my pressure vessel 1000mm is pressurized shell length. if I take standard plate (1250 or 1500 mm width) for shell fabrication then which length L0 (design length) to consider for fig. UG-29.2 & UG-80.1. .......?
REFER ATTCHED FILE FOR MAY TANK DETAIL.
KEJUL
KEJUL
RE: Design length_UG-29 & UG-80
Mike
But for shell calculation which length should consider for same.......
Kejul
Mike
I consider 1000 mm to calculate shell length... Is it right?
Kejul
Mike
