Gravel for backfill
Gravel for backfill
In my area, since we do not have flowable fill available, we are planning to use clean gravel (20mm~40mm) for backfill at depths where compaction cannot be attained. Close to the surface (GL-1.50m), the excavation is wider so compaction can be done. We are planning to use clay on top of the clean gravels compacted to 90% modified proctor.
The area then will be covered with grass. Surcharge loads are not expected. The excavation was done for placement of a utility manhole, so the gravel will be surrounding the manhole. Depth of excavation was approx. 2.5 m. No groudwater.
I think that clays due to their cohesion are more resistant to erosion so wash out of fines thru the gravel voids may not be an issue.
I have received different opinions from my reviewers, telling me that clean gravel is not adequate since it cannot be compacted and therefore can create future settlement problems. I think that with a slight vibration, gravels can "interlock" well and therefore I do not agree with the reviewer's opinion about future settlement.
Any comments about this? or any other options for backfill in areas where compaction cannot be attained?
RE: Gravel for backfill
