Wet Bulb calculation See thread403-273503
Hi there,
I am in desperate need of Wet Bulb temperatures for Delhi however, there are no records that I know of available. I came across this thread thread403-273503: Turning wet and dry bulb temperatures to Humidity and dew point, which outlined an excel function to calcualte the wet bulb from dry bulb, dew point, etc. However, I have no idea how reliable such a method is.
Is there any function that is reliably used to calculate Wb in excel?
Or any data sources of primary wet bulb temperatures that I have no come across?
Best
Best
RE: Wet Bulb calculation See thread403-273503
TTFN
[IMG http://tinyurl.com/7ofakss]
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
There is a homework forum hosted by engineering.com: http://www.engineering.com/AskForum/aff/32.aspx
Cannot use a psychrometric chart as I have hourly values for the whole year which I need to convert, which I am then using to calculate Wet Bulb Cooling Degree Days.
I have used an excel add in already but I have no idea how accurate it is.
TTFN
Best to you,
Goober Dave
Haven't see the forum policies? Do so now: Forum Policies
