Cable routing 2D drawing for 2 rows connector
I have done cable routing for 2 rows connector (12 pin connector, where 6 pin on top of the connector & other 6 pin at bottom of the connector).
I have query on calling out flattened cable in 2D drawing, since the cable will not point out to their respective connector position, everything will appear on one plane. Is there a way that it can be made to show in their respective pin position i.e. in front view of cable drawing, only 6 cable should appear, & about another 6 cable we can showcase it in side view.
Attached is the image on the same.
Any help on this is greatly appreciated …..
Warm Regards,
Dasrhan
Warm Regards,
Dasrhan
