Load cell amplifier
Load cell amplifier
I designed a force sensor using strain gauges to measure the force components in two directions. The forces creates compression and tension in x-direction while creates compression only in z-direction. I am looking for a commercial load cell amplifiers which has low pass filter (about 20Hz) and it can amplifier both compression and tension for one of them while only compression for the other. Could you please suggest a commercial amplifier that I can buy it with reasonable price.
Thanks in advance
Thanks in advance
RE: Load cell amplifier
Keith Cress
Well, have you looked at eBay anyway?? With a hundred offerings I see many makes and models that you can then over-pay for elsewhere. Just search the model numbers and you'll see the retail sites.
Keith Cress
Consider how easy it would be to abuse a system that allows any professor, staff, or researcher to tell the organization to buy stuff from e-bay.
STF
Keith Cress
