Power Plant : Coal to Natural Gas Conversion - U.S.A
What code would all of the new piping welds inside of the power plant be made to ? Is it A.P.I 1104 or does it change to something else ? I was told that it is 1104 until it gets to a distribution skid , then changes to B31.1 to the burners but that doesn't sound right to me .
Thank you for your time
RE: Power Plant : Coal to Natural Gas Conversion - U.S.A
Read the first section of ASME B31.1 (Scope, I believe) for a better definition of piping code boundaries.
MJCronin
Sr. Process Engineer
Each code has a section that defines its jurisdictional limits. Be careful to check with all stakeholders, sometime other entities get involved, for instance, DOT may require B31.4 inside the fence-line to the first vessel the pipeline is hooked up to.
