Need explanation about post- tension concrete
Hi every one;
I actually need conceptual explanation about post tension concrete. i study that first we use cable which pull up through machine until eliminate the stresses which developed in the cable and than pour concrete on form.
Here what mean by pulling and what is advantage of this kind of concrete. if someone clarify me that will be much appreciated.
((S.M.N))
((S.M.N))
RE: Need explanation about post- tension concrete
TTFN
[IMG http://tinyurl.com/7ofakss]
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
There is a homework forum hosted by engineering.com: http://www.engineering.com/AskForum/aff/32.aspx
Mike McCann, PE, SE (WA)
