Fluid Cavity in abaqus
Dear All
I am using Abaqus CAE and new on it. I want to simulate the heat transfer of an air filled capsule. This capsule is filled with atmospheric air and heated from its bottom. I want to simulate this problem such that the effect of the free convection of the air in the cylinder is taken into account.
For this purpose I have model the capsule in 3D in Abaqus 6.13, then in interaction module I have defined a "Reference point" as cavity point and the inside surface of the capsule as the cavity surface. In mesh module I have used an 8-node heat transfer brick (DC3D8)as the element type,
after submitting of the job the Error below generates:
"Only degrees of freedom 11 and above can be active in the model for this procedure. Check the procedure and element types used in this model."
What should I do to solve this error?
Thanks in advance
Vahab
Thanks in advance
Vahab
