straight tubes heat exchanger without baffles
I'm comparing a OTSG baffled and an ideal OTSG without baffles and pure counter current flow. I've more heat exchange correlations for shell side of the baffled case (locally cross-flow) but none for the no baffled tube bank.
Does anyone has suggestion about pure counter flow outside a tube bank ?
RE: straight tubes heat exchanger without baffles
Perfect !!
Thank you so muchwink
