F= .5, 90 degree plane
can you claim the nozzle drop in the 90 degree plane with nozzle in cylindrical shell? inside projection h= nozzle drop for
square cut nozzle.
RE: F= .5, 90 degree plane
engineer54, by "claim the nozzle drop" I assume you mean take credit for inside projection, A3?
Yes, subject to limits of reinforcemet, see UG-40, and subjecct to applicability of reduced F factor, see definition of "F" in UG-37. Note your opening detail must be considered as integrally reinforced, see UW-16(c). Note the total drop may exceed the allowable limits.
Mike
What I mean by nozzle drop is : Looking at the 90 deg plane, the distance measured from the top centerline of the nozzle to the corner of the square cut nozzle.
engineer54-
You should also read Interpretation VIII-1-13-12. I think it addresses your question, and provides a strong argument for you if you need to justify your approach. This Interpretation is available in the tail end of the 2015 edition of Div. 1 as downloaded from IHS.
