Need help calculating PPM (% Mol) in Gas samples
Hello all,
I am using an FTIR to attempt to calculate concentrations of impurities in air and oxygen. I have a standard that I know has 500.5 ppm (% mol) of CO2 and am trying to use the spectrum that I obtained from this sample to back calculate and find this value. Does anyone have any experience doing something like this?
RE: Need help calculating PPM (% Mol) in Gas samples
You also need to know the cell thickness to do that calculation. If you have that, then you can use Beer's law to estimate the concentration.
https://en.wikipedia.org/wiki/Beer%E2%80%93Lambert...
TTFN
[IMG http://tinyurl.com/7ofakss]
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
There is a homework forum hosted by engineering.com: http://www.engineering.com/AskForum/aff/32.aspx
