STABILIZATION
STABILIZATION
STABILIZATION
How can I improve the convergence of a model? Apart from remeshing and using stabilization.
What is the hourglass and in what way does it affect to the model?
Could be possible to modify the hourglass to enhance the convergence.
Thanks in advance.
RE: STABILIZATION
Hourglassing means that your elements deform in an unrealistic way, which can occur when you use reduced integration elements (for instance S4R instead of S4 in case of shell elements). Usually your deformations become (much) too large as a result of hourglassing.
The hourglass control settings in the element type selection window can be used to prevent bad effects from hourglassing.
Im not expecting that those settings will have much effect on your convergence.
What model are you running ? Describing that would help to understand the reason of convergence issues.
RE: STABILIZATION
Hey Michael!
I have no problem with the convergence, it was a simple question that you answered with great skill.
Thank you for responding to my question!
