high speed shift registers
i need to convert an 8 bit parallel word to serial. the problem is i have to do it very quickly approximatly 120MHZ. i have looked at several shift registers available but i need a bit of inspiration. has anyone tackled this sort of problem before?
RE: high speed shift registers
FireWire (IEEE1394)
USB
HotLink
other fiberoptic buses
TTFN
cbarn24050's advice is ideal if you want maximum flexibility of the encoding technique and have no control on the receiver.
irstuff's solution is ideal if you are sending the data over long distance or are designing the receive circuit too.
Cypress semiconductor's hotlink device (CY7C923/33)is simple to use although designed for 160MHz upwards (It automatically pads the stream if the parallel rate is slower). There's some good apps notes on Cypress website too.
<nbucska@pcperipherals.com>
