low budget mold for prototype
I made some plastic mold before and they are very expensive. Now, I want to make a tyre and need to test the rubber material (not sure if I can be success) that's why I seeking if there is any low budget mold for my purpose. Let's say I will need a mold for testing material for molding 300 times. Is there a mold for low usage low budget like this? Or is there any other method I should use for doing a rubber part prototype.
RE: low budget mold for prototype
Dan - Owner
http://www.Hi-TecDesigns.com
Silicone mold is very soft. it is able to use in regular molding machine?
Not durable enough for use in machinery, generally.
But, your problem statement perplexes me.
Are you looking to make material test samples of simple geometry from putative rubber formulations,
or are you looking to make tires in a temporary mold?
Mike Halloran
Pembroke Pines, FL, USA
