API 650 Tank Settlement
As per API 650 7.3.6.6, API provide a limit on differential and uniform settlement
but it is also said that if the settlement will be over the specified by API it shall be reported to the purchaser for evaluation.
Question is how to compute the maximum required settlement (Differential and uniform)
and how to determine the maximum dishing settlement/sagging of bottom plate.
Thank you for your support.
