Industrial UPS system. Suggestions please.
Hey, I am looking for a UPS system that can provide stabilized and filtered power for a vegetable extraction plant. According to the engineer, the required system should have input circuit breakers, maintenance bypass switch, bypass transformer, distribution breakers etc. Is there any UPS system suitable for this application? One of my friend suggested Staticon power backup systems. Is that good? I am looking for suggestions from experts in this industry. It will be great if it has more than 85% efficiency.
RE: Industrial UPS system. Suggestions please.
I recommend: forum238: Electric power & transmission & distribution
Keith Cress
So, the OP needs to do a websearch for "industrial ups" like:
http://www.ltipowersystems.com/lti-difference.html
http://powerquality.eaton.com/Products-services/Ba...
TTFN
[IMG http://tinyurl.com/7ofakss]
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
There is a homework forum hosted by engineering.com: http://www.engineering.com/AskForum/aff/32.aspx
Important selection criteria that is often overlooked is the time required to start up the UPS. Some switch on in a fraction of a period, others are slower. Depends on your loads.
