In Simulate, extracting nodal resultant forces and displacements from a global model
I have a large assembly (global) FEA model in Creo Simulate that I have successfully solved. The solve has multiple load cases. I want to extract the resultant forces and displacements corresponding to each of these load cases across selected surfaces of this global model. I would like to use these forces and constraints on a smaller breakout model with more accurate geometry and finer mesh. Is it possible to do this in Creo/Simulate? Appreciate any feedback from the community. Thank you!
