Abaqus Error code 1073741795
I just Installed Abaqus in my computer and Abaqus CAE 6.14 works fine. But, every time I submit a Job it runs for 2 seconds and then I get the following message:
The executable standard.exe aborted with system error code 1073741795. Please check the .dat, .msg, and .sta files for error messages if the files exist. If there are no error messages and you cannot resolve the problem, please run the command "abaqus job=support information=support" to report and save your system information. Use the same command to run Abaqus that you used when the problem occurred. Please contact your local Abaqus support office and send them the input file, the file support.log which you just created, the executable name, and the error code.
I looked for information already and It seems to be something related with memory allocation but I am not sure...
does anyone have ever get this error before? do you know anything about it? is there any solution??
my computer is a NEW Lenovo - 15.6" Laptop - AMD A8-Series - 6GB Memory - 500GB Hard Drive with windows 7
Abaqus used: Abaqus 6.14
RE: Abaqus Error code 1073741795
I would recommend doing as the error message states. Run the "abaqus job=support information=support" command, contact your local Abaqus support office, and have the files available for their review.
