theUFsession.Modl.CreateCurveFromEdge
I am using the subject function to extract the edges from a face of a solid body. Here's the snippet of code:
CODE --> vb.net
For Each thisEdge As Edge In largestFace.GetEdges
            Dim newCurve As NXOpen.Tag = NXOpen.Tag.Null
            theUFsession.Modl.CreateCurveFromEdge(thisEdge.Tag, newCurve)
        Next
It works great; however, it is returning the tag of the line. Next I want to take that line and put it on a specific layer.
so, I developed this code from journaling:
CODE --> vb.net
Private Sub MoveToLayer(ByVal iLayer As Integer, ByVal obj As NXObject)
        Dim displayModification1 As DisplayModification
        displayModification1 = theSession.DisplayManager.NewDisplayModification()
        displayModification1.ApplyToAllFaces = False
        displayModification1.ApplyToOwningParts = False
        displayModification1.NewWidth = DisplayableObject.ObjectWidth.Two
        displayModification1.NewLayer = iLayer
        'Dim objects1(0) As DisplayableObject
        'Dim line1 As Line = CType(workPart.Lines.FindObject("ENTITY 3 24 1"), Line)
        'objects1(0) = line1
        displayModification1.Apply({obj})
        displayModification1.Dispose()
    End Sub
I need to convert the tag of the line into an nxobject. How do I do that?
RE: theUFsession.Modl.CreateCurveFromEdge
The DisplayModification object only operates on objects of type DisplayableObject. You'll have to get the curve object with the NXObjectManager and cast it to a displayable object. If you are using "Option Strict Off", you can let the compiler do the conversion for you:
CODE
Dim newCurveObj as DisplayableObject = Utilities.NXObjectManager.Get(newCurve)
www.nxjournaling.com
Isn't that sloppy coding. I was looking for a way to cast a tag into an line or NXobject.
Quote (EngProgrammer)
That's a matter of opinion. Personally, I don't have a problem with it; especially in cases such as yours. We know that the CreateCurveFromEdge function will return the tag of a curve object. We can do the conversions ourselves, or we can let the compiler do it; I see no advantage to doing it manually.
A tag is just an integer value. The only feasible way to get an object from a tag is through the NXObjectManager. The NXObjectManager.Get() method will return a TaggedObject. So, if you like to do the conversions yourself, you could do something like this (no error checking in the following example):
CODE
Dim newTaggedObj As TaggedObject = Utilities.NXObjectManager.Get(thetag)
Dim newDisplayableObj As DisplayableObject = nothing
newDisplayableObj = CType(newTaggedObj, DisplayableObject)
Still having problems moving the line to a layer. It seems like it moves it but when I turn on that layer there is nothing.
CODE --> vb.net
'  Find Largest Face from the Face Areas
            Dim newCurveObj As DisplayableObject
            newCurveObj = Utilities.NXObjectManager.Get(newCurve)
            newCurveObj.Layer = 99
        Next
Try calling newCurveObj.RedisplayObject() after assigning the new layer. If that doesn't do the job, I'd try saving all the new curves into a list (or array) and using a DisplayModification object to move them all to the new layer.
For comparison, here's how you do it using SNAP functions:
CODE --> VB
Public Class MyProgram
    Public Shared Sub Main()
      ' Example object for illustration
      Dim widget = Snap.Create.Widget
      ' Cycle through  edges, creating curves
      For Each edge In widget.Edges
         Dim curve = edge.ToCurve
         curve.Layer = 200
      Next
    End Sub
End Class
If you don't have access to SNAP, you can simplify your code by calling NXOpen.UF.UFObj.SetLayer, rather than using the DisplayModification approach. This SetLayer function receives a Tag as input, so things are easy.
