DatumPlane
DatumPlane
DatumPlane
How do I get a handle on the DatumPlane that is in the workpart. I developed this code and having a problem debugging it.
CODE --> vb.net
Function GetDatumPlanes(ByVal in_part As Part) As DatumPlane()
        Dim a_DatumPlane As Tag = NXOpen.Tag.Null
        Dim type, subtype As Integer
        Dim bList As ArrayList = New ArrayList
        Do
            theUFsession.Obj.CycleObjsInPart(in_part.Tag, _
                UFConstants.UF_datum_plane_type, a_DatumPlane)
            If Not a_DatumPlane.Equals(NXOpen.Tag.Null) Then
                theUFsession.Obj.AskTypeAndSubtype(a_DatumPlane, type, subtype)
                If subtype = UFConstants.UF_datum_object_subtype Then
                    bList.Add(Utilities.NXObjectManager.Get(a_DatumPlane))
                End If
            End If
        Loop While Not a_DatumPlane.Equals(NXOpen.Tag.Null)
        Return bList.ToArray(GetType(DatumPlane))
    End Function
RE: DatumPlane
Below are two methods:
CODE
Option Strict Off
Imports System
Imports System.Collections.Generic
Imports NXOpen
Imports NXOpen.UF
Module Module1
    Dim theSession As Session = Session.GetSession()
    Dim theUfSession As UFSession = UFSession.GetUFSession
    Sub Main()
        If IsNothing(theSession.Parts.BaseWork) Then
            'active part required
            Return
        End If
        Dim workPart As Part = theSession.Parts.Work
        Dim lw As ListingWindow = theSession.ListingWindow
        lw.Open()
        Const undoMarkName As String = "report datum planes"
        Dim markId1 As Session.UndoMarkId
        markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, undoMarkName)
        Dim myPlanes As New List(Of DatumPlane)
        myPlanes = GetDatumPlanes(workPart)
        lw.WriteLine("number of datum planes: " & myPlanes.Count.ToString)
        Dim myPlanes2 As New List(Of DatumPlane)
        myPlanes2 = GetDatumPlanes2(workPart)
        lw.WriteLine("number of datum planes: " & myPlanes2.Count.ToString)
        lw.Close()
    End Sub
    Function GetDatumPlanes(ByVal thePart As Part) As List(Of DatumPlane)
        Dim theDatumPlanes As New List(Of DatumPlane)
        For Each temp As DisplayableObject In thePart.Datums
            If TypeOf (temp) Is DatumPlane Then
                theDatumPlanes.Add(temp)
            End If
        Next
        Return theDatumPlanes
    End Function
    Function GetDatumPlanes2(ByVal thePart As Part) As List(Of DatumPlane)
        Do
            theUfSession.Obj.CycleObjsInPart(thePart.Tag, UFConstants.UF_datum_plane_type, a_DatumPlane)
                theDatumPlanes.Add(Utilities.NXObjectManager.Get(a_DatumPlane))
            End If
    End Function
    Public Function GetUnloadOption(ByVal dummy As String) As Integer
        'Unloads the image immediately after execution within NX
        GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately
    End Function
End Module
www.nxjournaling.com
RE: DatumPlane
How about just "workpart.Datums"? I just looked at that and it gives me all the datums within the workpart. Sorry for the post. I was making it more complicated than it needed to be.
RE: DatumPlane
That's the method I used in the GetDatumPlanes function above; the Datums collection holds datum planes and axes (possibly csys and points as well), you'll need to sort out the planes from the rest.
