minimum thickness of seal face
Dear Experts,
For Mechanical Seal ,
How did I know the minimum thickness of seal face can be use after wear. Mostly in the case of carbon face.
If I decrease a working length ,in order to reduce a Spring force. It will fix the problem or not.
Thank you
Thank you
RE: minimum thickness of seal face
If you are having other issues with the sealing arrangement that is prompting you to question the design then I would recommend posting your issues in this forum or contacting the seal manufacturer and working through the issue. Could be that you have the incorrect design altogether.
As a general guideline, spring forces are very common among seal designs (and even across different seal manufacturers. So I say that to say that your issues likely are not a design problem with working length or spring force.
