Butt weld CJP Qualifies Fillet weld multipass and Single Pass?
Could somebody advice me at the following question:
Quote:
Acc.to Table 4.2,note D) CJP groove weld qualification on any thickness or diameter shall qualify any size of fillet or PJP groove weld for any thickness or diameter
Question: Would a CJP Groove weld Qualify a Multi layer and Single layer fillet weld
RE: Butt weld CJP Qualifies Fillet weld multipass and Single Pass?
what code applies?
Best regards - Al
AWS D1.1 2010
It is best to expand the WPS by qualifying fillet weld samples to establish the welding parameters that will produce acceptable welds.
My recommendation is to qualify the fillet welds first to establish acceptable welding parameters and then use those parameters (voltage, amperage, travel speed, etc.) to qualify the CJP groove test assembly.
Best regards - Al
