Gas Spring Handbook
Gas Spring Handbook
I'm working on large steel door design, 4X2 m, with isolation, estimated weight 100kg.
the door will be opened with 2 gas springs and I'm searching for good handbook on this topic.
I want to learn how to choose gas springs and how to connect them to the door ,and to the door frame.
Thanks in advanced.
Thanks in advanced.
RE: Gas Spring Handbook
Another source for gas springs is Guden.
Kyle
If the two gas springs are used to both lift this 100kg door and hold it open, there are other safety related factors to consider. For example, would failure of one of the gas springs cause the 100kg steel door to slam closed and possibly injure someone? Gas springs have limitations with regards to durability, since they lose function if there is leakage of the working gas.
If what you require is some type of assist device to allow the door to be opened/closed easily, you might consider some type of mass balance system.
