No heat transfer within part
I have an annoying problem with my heat transfer results. I have a deformable die part where there is a cooling channel integrated within. I defined the channel and the rest of the die as two sets and used predefined fields to define different temperatures for them. I also used one simulation with a dynamic temperature-displacement and one with a coupled temp-displacement.
Also I set the thermal coefficients for both materials (die and billet) like conductivity, specific heat and expansion.
Nevertheless, at the end, when I view my results there is no temperature change within my die (heat transfer between billet and die seems to work). More importantly it never shows me the temperature I set for my channel...
What am I missing or doing wrong???
Thanks in advance.
mageldai
Thanks in advance.
mageldai
RE: No heat transfer within part
Why should I use boundary conditions when I already used predefined fields? Are boundary conditions not fixed properties which won't change during the simulation?
Also what exactly do you mean with "gap conductivity"?
