ETAP TCC fault current
Hi, I am trying to create a TCC curve with TCC clipping current but I was not able to see the clipping current in the graph. On checking TCC kA for each protective device, I see no values in them. I ran fault analysis and was able to insert SLG fault at a bus to view the fault current but I see blank space in TCC kA of that particular protective device. How can I correct this problem?
Thanks in advance.
Thanks in advance.
RE: ETAP TCC fault current
There is no great thing in the ETAP TCC curves except flexibility. Rest all are the marketing gimmicks.
