2 easy questions
2 easy questions
1) What does the dotted line represent on the sheets? 2) I'm trying to get my layouts to print to 11 x 17. How do I go about that - do I have to start in a certain template? Currently, when I go to print and change the config I have to go through several config changes and add borders here and there and it won't have even borders all the way around.
RE: 2 easy questions
Per MKK1 3 Apr 12
1. Go to desired sheet
2. Right click on sheet tab
3. Click on Print Configuration Manager
4. Select (or create first one) desired print configuration
5. Click Activate!!!
Click New.
Based on: (Default)
Type in a file name. Click OK.
This opens Print Configuration dialog box. You can make your adjustments here.
Click Save. Click Close.
Sylvia
