aseembly to part file
I have assembly of many parts.
I want to make it all in one file, so to convert assembly into part file
I did it several times saving assembly as stp file, open stp and save stp again
I do not need history.
Did not notice some strict law in doing so, and now I have a problem doing it.
I work with NX7.5
Anyone knows the way to do it?
I work with NX7.5
RE: aseembly to part file
What kind of problems did you run into with the STP files?
www.nxjournaling.com
If you really want it to be a single solid body, unite the components before doing your export.
Ben Loosli
You need to add each component to your assembly.
Thanks a lot, I will write it down.
