dump truck station design
Design issue.
Problem: dump truck trailers tip over to the side when unloading material. The cause could be an uneven floor, material stuck in the dump platform,etc. These trucks weigh about 45k lbs (load included).
In order to prevent tip overs, I would like to design a dump station made of bollards( or some other type of material). There will be 2 rows of bollards and the dump truck will be in between, question is how much force can the bollard withstand at impact when truck tips over to the side. What type of bollards would I need? The bollards will have to be 10' tall or more, is this feasible? How deep the bollard would need to be to withstand a falling truck.
Of course, I could have an even floor and problem fixed. But where I work, trucks dump on a regular basis, and floor surface don't stay even for a long period of time. Trucks unload any kind of materials from engine blocks to concrete blocks; these materials damage the floor quickly.
I made some calculations, taking 0.5g sideways force (truck's cargo weight) and calculating the kinetic energy, based on bollard design for vehicle crash impact(linear motion). I assume a speed of 5mph, and bollard deflection of 3'. I can allow the bollards to have deflection on impact, maybe 3' or less. Structure engineering is out of my realm, so I figured I could get some tips from you guys.
Any suggestions or other design approaches will be appreciated!
RE: dump truck station design
The foundations would likely be substantial to handle the overturning force. I think you should look at several bollard manufactures and see what standards they state their bollards are designed to. Find the standards and see what loading they should be expected to handle.
Likely this is a special request and you should consult a structural engineer for proper advice.
Look into prevention practices or alarms.
There are some anti-rollover alarms that are available.
http://www.3dx.com.au/terraintrakka/applications#a...
what you want / need instead is two high concrete walls with buttresses just wide enough apart for the truck to squezze in and then any out of balance forces will result in only a small movement before the truck hits the wall.
Anything which allows the truck to start falling over and then arresting the fall is difficult to design, ends up being very big and if its as common as you say, would need replacing on a regular basis.
Again, thank you guys for your help.
Prevention is much better than cure though and preventing movement is much better than arresting it once it starts.
