Equation constraint
Equation constraint
I need to use equation constraint to impose this equation on two nodes A and B: u(A) - u(B) = C
C is a constant = deformation x L
The problem is that i don't know in Abaqus how to include in the equation constraint the constant C, i know that the equation should be written u(A) - u(B) - C = 0 but where do i put the C?
Thank you so much in advance
RE: Equation constraint
Hint: Prescribe a nonhomogeneous constraint.
Are you new to this forum? If so, please read these FAQ:
http://www.eng-tips.com/faqs.cfm?fid=376
http://www.eng-tips.com/faqs.cfm?fid=1083
