NX 10 NASTRAN Temperature loads inactive
I have been trying to do a thermal analysis using NASTRAN, but the thermal loads are inactive even if I have applied them. what should I do? The simulation navigator says so.
RE: NX 10 NASTRAN Temperature loads inactive
Did you select the correct solution? I think for thermal analysis, you need to select Sol 153 or Sol159...
Tuw
Possible to share your work files?
Tuw
Work files? do you mean .dat or .f06 files?
Best Regards
.fem and .sim file would be good..
Tuw
