Reverse engineering for rubber tyre
I want to make some toy car tyre. And I have no idea what are the material needs to be mix. So, I am planning to send some rubber tyre to a lab for analysis. According to the lab, they said they can get close to 95% of the material contains in the tyre. And they will let me know how the materials react into the rubber. So that I can fine tune the end product. It sounds too good to me. I think it should not be so easy to do the reverse engineering. So, I have some questions:
1. Analysis then use the same contents to mold the tyre. You think it works?
2. How close I can get to the lowest.
3. Is there any treatment of material? Ex, dry age for a steak. Do I need to dry age for a material.
4. Is there any company/person that can help me to get success?
thanks
thanks
RE: Reverse engineering for rubber tyre
For the high end tyres you could use norsorex http://www.astrotech.at/index.php/griptyre.html, otherwise natural rubber is a good option.
The design of the thread is very important too.
Natural rubber is good but not good enough for my application. I had some tyres on hand made with natural rubber, they are not in competition level. It must added with something filler or other in order to provide extra grip. But I have no clue on what should be mixed.
Is the norsorex the only material that can enhance natural rubber for my application? What about other I should try?
For the thread on tyre, usually we use no thread to provide max traction. thank you
You could add tackifiers to your compound, fe PIB for more grip. Maybe another additive that melts at 40-50°C. Don't use any waxes or anti oxidant, anti ozonant as they tend to migrate to the surface where they'll act as a non sticky layer.
To be honest I don't think you can say "NR is not good enough" just by feeling some tyres. They just might not be optimized for the one good heat.
