Hex bolt VS Studbolt
Hi everyone,
Could somebody explain/advise me as following detail:
-Why Hex bolt is not widely use in Oil & Gas industries? What is the reason that limit or restrict to use the Hex bolt ?
-When refer to API 570 & 510, Is it state any objection to use the Hex bolt?
-Any advantage and disadvantage to use the Hex bolt instead of Studbolt?
Thanks for any help.
RE: Hex bolt VS Studbolt
FWIW, most of the biodiesel, ethanol, and vegetable oil extraction plants were built using Gr.5 machine bolts, *not* the needed heavy hex bolting. Guess they liked to go shopping at Tractor Supply, etc. instead of an industrial supply that carried heavy hex like B7's.
