4s LiFeP04 Battery Pack - PCM Problem
Hey everyone, I built an 18650 4s battery pack with a PCM, but I’m having trouble with the PCM part. I followed the wiring diagram they provide & I could swear that I have it wired correctly, but I’m not getting any voltage out of the lead wires from the PCM.
I know I have the batteries connected correctly because the voltage is correct when I measure it directly from the (-) and (+) tabs on the pack. Maybe the PCM is defective..?
It’s damn near impossible to find a video or clear instructions on the web, for how exactly to wire these things, so I thought this would be a good place to get some feedback. I’d appreciate it if anyone could point out any mistakes I’ve made or something(s) I should have wired differently.
Here’s a pic of the wiring diagram they provide, and a pic of how I have the batteries wired to the PCM:
RE: 4s LiFeP04 Battery Pack - PCM Problem
I'd expect the PCM to NOT give you any power if the batteries are low as that is an important aspect of the PCM function - preventing overdischarge.
Of course they can also protect from over current draw.
Could be your batteries are too low or your load is to great?
Keith Cress
Thanks for the reply. Good to know it's wired correctly (I'll take your word for it -- from your website, it looks like you know what you're talking about
I just re-checked all the connections & they're all solid, with no short circuits. Wow, this is super frustrating. I guess I'll have to contact the place I bought it from (all-battery) and tell them I think it's defective. Hopefully they stand behind their products..
Yeah, it sounds like it's probably defective - it happens. :/
Keith Cress
I honestly have no clue why that did the trick, but I guess ignorant tinkering gets the job done in some situations
I just realized the wiring diagram / directions doesn't show where to connect the charger leads though.. I can't decide whether to connect it to the "P" or "B" tabs -- It seems like the P tabs would be the wrong ones, as they're the outlet for the power, but I don't see how the PCM would be able to cut off the charging / prevent overcharging if I were to connect the leads to the "B" tabs.. Plus, I don't want to fry the circuit from an improper connection.
I'd take your word for it though -- where would you connect the charging leads?
A big hazard is charging so yeah, I'd really expect the PCM to protect and BALANCE the charging of each cell, so yes, I vote for the Ps.
Keith Cress
http://www.batterysupports.com/24v-252v-7s-30a-7x-...
http://www.batterysupports.com/4s-144v-148v-168v-1...
TTFN
[IMG http://tinyurl.com/7ofakss]
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
There is a homework forum hosted by engineering.com: http://www.engineering.com/AskForum/aff/32.aspx
