How to switch off Warning messages
I have written a journal which is performing a set of actions on each child part of a root component. But if the user doesnt have write access to child part, it prompts a warning message. Although my journal works perfectly fine even on these parts, the problem is if the root assembly is have many parts then user will have to click ok on this message multiple number of times. Is there a way I can avoid this warning message.
Attached is the warning message
RE: How to switch off Warning messages
I doubt if there is a way to turn them off, but if you use two monitors there may be a way for them to show up in your other monitor.
