Buckling analysis for pure bending of Flat Plate using MPC
Buckling Analysis (Local)
I want to model pure bending on the flat plate by using MPC with a moment applied to the reference node which is connected to the end of the flat plate. After successfully modelling this, I will use this method to model pure bending of an I section. Further I plan to use this method in a inelastic buckling (non-linear) analysis for my thesis at USYD.
I have modelled a 100x300x5 flat plate use shell elements. Looking at the abaqus manual, a link MPC seems most suitable, however I was not able to get it to work. Error message, "2 nodes have inactive dof on which boundary conditions are specified...". I think this is because of the dof limit of a shell element to support rotations.
How should approach this problem? If there are is any further information is required please message me. I have attached the files here.
Any help will be much appreciated, and may be acknowledged in my final thesis paper.
RE: Buckling analysis for pure bending of Flat Plate using MPC
bending buckling (inplane or out-of-plane) of a flat plate is much more complex than for an I beam.
