Getting relative views of each body of multibody part
I am trying to automatically create drawing document with number of sheets that match number of bodies in multibody part that is active and opened prior to running the macro. Each sheet would contain relative view of one body. What does happen when running macro as shown below, I do get number of sheets but without any models in it (empty template drawing). My guess is that I am missing the command that drops view onto the sheet, therefore please if anyone can take a look and let me know what I am missing here.
Thanks.
' Only precondition for macro is to have multibody part open
Dim swModel as ModelDoc2
Dim pathName As String = ""
Dim swPart as PartDoc = Nothing
Dim swFeature as Feature = Nothing
Dim swBodyFolder as BodyFolder = Nothing
Dim numberOfBodies As Integer = 0
Dim allBodies As Object ' array
Dim swBody As Body2 = Nothing
Dim swDoc As ModelDoc2 = Nothing
Dim bodyName As String = ""
Dim swDrawing As DrawingDoc = Nothing
Dim firstView As View = Nothing
Dim bolBody As Boolean = False
swModel = swApp.ActiveDoc
pathName = swModel.GetPathName ' path name is string value
swPart = swApp.ActiveDoc
If swPart Is Nothing Then
Exit Sub
End If
swModel = swApp.NewDocument("D:\Macros\Macro_A.drwdot", 0, 0.2159, 0.2794) ' opening new drawing document
swFeature = swPart.FirstFeature
Do While Not swFeature.GetTypeName2 = "SolidBodyFolder"
swFeature = swFeature.GetNextFeature
Loop
If swFeature.GetTypeName2 = "SolidBodyFolder" Then
swBodyFolder = swFeature.GetSpecificFeature2
numberOfBodies = swBodyFolder.GetBodyCount
allBodies = swBodyFolder.GetBodies()
For i = 0 To (numberOfBodies - 1)
swBody = allBodies(i) ' swBody is Body2 and allBodies is array of bodies (object)
bodyName = swBody.Name
swDoc = CType(swApp.ActiveDoc, ModelDoc2)
bolBody = swDoc.Extension.SelectByID2(bodyName, "SOLIDBODY", 0.0254, 0.038, 0.1135, True, 0, Nothing, 0)
bolBody = swDoc.Extension.SelectByID2("Front Plane", "PLANE", 0, 0, 0, True, 0, Nothing, 0)
bolBody = swDoc.Extension.SelectByID2("Right Plane", "PLANE", 0, 0, 0, True, 0, Nothing, 0)
swDrawing = CType(swDoc, DrawingDoc)
firstView = swDrawing.CreateRelativeView(pathName, 0.0972, 0.133, 0, 1)
If i < (numberOfBodies - 1) Then
swDrawing.NewSheet("Sheet" & (i + 2), 0, 0, 0, 0)
End If
Next
End If
