using distillation tower products coolers to produce steam
I'm working on new distillation unit heat ex-changers design, at this unit, the products get cooled after getting out of the tower by
exchanging with treated water, the water will be converted into steam, which can be used in the plant,
the question is, is that will make any difference at coolers design (I thought to use floating heat shell & tube heat ex-changer, TEMA AES, class R)
thank you in advance
ahmed bahgat salim
ahmed bahgat salim
RE: using distillation tower products coolers to produce steam
TEMA S design was popular many years ago, but is prone to leaks.
You migt get better heat recovery if we break up this heat exchange duty into 2parts, one for sensible heating and the next for vaporising, with the column product running in the reverse direction. The sensible heating HX could be a TEMA AEU or BEU.
