Bottom plate failures at SWS tension chords
During inspections and plan review I have noticed the engineer allows 8" -12" from the corner holddown anchor bolts to the 2-2x4 chord of a wood SWS.
It seems the moment on the plate which is acting as a cantilever is much higher than designed for.Also the shear is higher than a 2x4 can take( especially on multistory buildings using type 1 SWS.)
Am I off base here? I recall these failures in testing.
Inspector Jeff
RE: Bottom plate failures at SWS tension chords
I don't do many wood frame shear walls, but that sounds suspicious. When specifically designing shear walls, I always pass by the mud sill with Strong-Tie HDU's or similar.
"It is imperative Cunth doesn't get his hands on those codes."
The Canadian code allows this for a certain range of load.
I see this called out often, but I normally see an accompanying note adding a double stud adjacent to the holddown and providing edge nailing to the double stud.
