Bending stiffness with centrifugal force
H Everyone!
I'm calculating the bending stiffness for a helicoper blade part, which links the blade to the the cube. That fitting was modeling by Femap. Next, a unitary force was applied at the tip of the blade in order to obtained the node rotation (y) where the bending stiffness (N/m) want to be calculate (euler theory). So, how this procedure should be done take into account the blade rotation (492 RPM) with the centrifugal force?
thanks
thanks
